Critical_Mass 10 Posted February 11, 2006 Ive taken the brake ducts off my car to get the bumper off. Ive discovered a plug on the drivers side one. However i couldnt see a wire with a plug to go into it? Can someone tell me what it is, what it does, why there isnt anything plugged into it and should should there be? thanks guys. Quote Share this post Link to post Share on other sites
Andy Brookes 0 Posted February 11, 2006 I think thats the outside temp sensor, would think the plug that should plug into that is stuffed up inside the bumper somewhere. Would think someones had the bumper off in the past and forgot to plug it back in. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 11, 2006 Yeah - check yer MFA to confirm... if it works then they may have relocated the temp sender, air box maybe... Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted February 11, 2006 MFA works ok, bar the fact it resets itself when ignition is turned off. but thats not related to this. Is the temp sensor blue? cant see where it can be. Thing is ive had bumper off myself due to damage and have replaced it with a different one. Couldnt see no wires pretruding out of the bumper that could be for this. Quote Share this post Link to post Share on other sites
Ronan 0 Posted February 11, 2006 This is what the temp sensor looks like, sure it shouldn't plug into anything in the brake duct, i moved mine so i could see what temp the air was I was taking in. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted February 12, 2006 no nothing like that around my airbox. Quote Share this post Link to post Share on other sites
selbekk 0 Posted February 12, 2006 could it be a connector to the us style side indicators? I think both euro and us spec cars had the same wiring loom, so there would be a set of plugs for both locations. the temp sensor is inside the wing, if i remember correctly. Quote Share this post Link to post Share on other sites
