Atlas 0 Posted August 31, 2003 Right, need your help boys. Looking to put 17s on my 1.8 16v,what is the best width to go for and what should the offset be, so i know they are giving me the right ones?. Also looking to slam it about 35mm, should get away without any arch mods shouldnt i? :?: Quote Share this post Link to post Share on other sites
G60 0 Posted August 31, 2003 slammed is 80+mm son ;) you shouldnt need any arch mods if you get the right offset.. if anything you may have to cut/remove plastic wheel liners. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted August 31, 2003 35mm will be fine aslong as you are sensible with your wheel choice... :lol: Quote Share this post Link to post Share on other sites
kevin 0 Posted September 1, 2003 im running 17" momos on -35mm apex suspension and have no rubbing problems at all, only back box hitting rear beam with weight in the rear of the car. Quote Share this post Link to post Share on other sites
Atlas 0 Posted September 3, 2003 cheers boys :D Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted September 3, 2003 Offset should be 35mm or 38mm Quote Share this post Link to post Share on other sites
