Atlas
17s on my 1.816v
Right, need your help boys. Looking to put 17s on my 1.8 16v,what is the best width to go for and what should the offset be, so i know they are giving me the right ones?. Also looking to slam it about 35mm, should get away without any arch mods shouldnt i? :?:
slammed is 80+mm son ;)
you shouldnt need any arch mods if you get the right offset.. if anything you may have to cut/remove plastic wheel liners.
im running 17" momos on -35mm apex suspension and have no rubbing problems at all, only back box hitting rear beam with weight in the rear of the car.
