Rick_ford55
horny
My horn has stopped working and i dont know why.....I dont us it much but went to use it the other day and nothing happened got to go in for an mot soon. worked before cant remember last time i used it. checked fuses but they all seem fine. any help much appreciated. by the way its a vr6 94 plate
Probably the contacts on the back of the steering wheel are dirty or just not touching the steering column side.
Remove the steering wheel to check, 24mm nut in the middle.
Gavin
The contacts on the back of the steering wheel seem fine i can just pull out the section for the horn from the steering wheel and everything there seems fineas i said it was working not that long ago but sometimes you had to press it a few times for it to work!
it deffo sounds like the contacts. take of the entire wheel and check every connection throughout the wheel. there are a few iirc
Mine was relocated under the battery tray to fit the intercooler in. Will check the connections though. Does a clicking relay mean it's working??
