Roger Blassberg 0 Posted February 22, 2006 oooooh !! Sehr interessant !! Best wishes RB Quote Share this post Link to post Share on other sites
VWci 0 Posted February 22, 2006 does "complete injection swap from ABF engine" make difference in performancewise ? Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 22, 2006 VWci said: does "complete injection swap from ABF engine" make difference in performancewise ? Not really, unless you have it's more advanced ECU mapped to the spec of your engine. A standard ABF with it's system is slightly more torquey mid range than a KE-Jet 6A/9A 16v, it's just a newer and more advanced system. As it's fairly easy to get 170bhp plus from a standard K-jet system I wouldn't bother with an ABF fuel system swap hassle wise. David. Quote Share this post Link to post Share on other sites
VWci 0 Posted February 22, 2006 thanks......;) Quote Share this post Link to post Share on other sites
VDUBBER 0 Posted February 22, 2006 Any one know how much it would cost to get the whole mod done? Is it an easy job? Sounds like i might have to get it done. Cheers guys Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 22, 2006 You could get the engine and box for around £500, there is a bumped MK3 16V on autotrader for 550 at the moment. Fitting it is no biggy. It'll all plug into the fusebox AFAIK. I bet you could get someone to do it for less than a grand. It would take 2 solid days to DIY. Gavin Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted February 23, 2006 could anybody tell me if the throttle body on the 2.0l is bigger than the 1.8 16v and is it a straight swap Quote Share this post Link to post Share on other sites
Bally 0 Posted February 23, 2006 Done the exhaust cam mod on myn... does make abit of a difference... Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 23, 2006 Adam Darby said: could anybody tell me if the throttle body on the 2.0l is bigger than the 1.8 16v and is it a straight swap The same except the small plate on the 2 litre has a big lump on it.. IIRC Gavin Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted February 23, 2006 what do you mean a big limp? will it flow any better than the 1.816v Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 23, 2006 There is a lump of steel or something on the plate. Not sure of the purpose, maybe to increase torque?? It would reduce airflow I guess but whether there would be any gain from removing it I don't know. You can just stick in the plate from a KR TB. If you take off the elbow onto the TB and have a look in you'll see it, may have to open the throttle as I think it's on the back of the plate. Gavin EDIT I can see where you are going now and if it were my turbo C I'd remove it if one is fitted. The 2 litre one is no bigger, so no use to you. Quote Share this post Link to post Share on other sites
flusted 0 Posted February 23, 2006 Keep your eyes peeled in the engine section for my new 16v throttlebody that i should be getting tommorrow. Will post pics as soon as i get it Quote Share this post Link to post Share on other sites
wilkes 0 Posted February 24, 2006 i removed the little lump of metal from mine ,dont know how much difference it made as i ported/polished the throttle body at the same time ,but together they made it much more drivable ,especially at low revs ,made it a bit quicker ,so id recomend it considering its basically free Quote Share this post Link to post Share on other sites
