Deanso
Door won't open!!
Hi guys,My passenger door is closed an the pin won't
rise so the lock won't release the handle.This happened
at xmas there, so I bought new handle repairs off dave16v.
I was about to replace them when it started working again
so i didn't bother.
It seems to be the same thing as before.If i turn the key in
the door it tries to go up and i can even hold it 2/3s up if i pull on
it at the same time.Local vag said it's 3wks before they can look
at it!! Has anyone ever had this prob.(girlfriend is wreckin seat!!)
please help
probably an electrical fault with the vacuum release mechanism mate - mine did this intermittantly in the past. Got an auto-sparky to fix it for £20.
Yeh that could well be it mate.You don't know what he did
do you? What i mean is, did he replace anything or just
repair it?
He just removed the door card - which can be a nightmare if you can't open the door - so try a few times to open it - mine worked occasionally. I remember him looking at the black hose part - in the door hinge and I think he just used WD40 to lubricate the mechanism. As VR6 says though - I'm sure you can find more info on the search.
Hope that vague account helps!
Update. Just incase it happens to you,I sprayed
wd40 using the straw between the door and the
rear quarter panel all over the lock(completely
drenched it)left it for a few minutes a it opened
haha... wd40 is great! Cheers for help
