Sy_VW
Radiator fan motor
The radiator fan on my 92 Corrado G60 only comes on at the higher of the two temperatures. The motor has a three pin socket allowing for two speeds.
It has a new switch which should enable the fan to come on firstly at 85 then faster at 92.
An auto electrician told me that the fan motor was on its way out and could do with replacing.
I was then told by someone else that the radiator fan motor will either work or not; not at one temperature/speed or the other.
Any ideas?
