sambo
Fog lights...
Hi folks, how do
Got a problem with foglights, basicaly i'm getting no voltage at all at connectors
Car is a mk1 golf but entire electric set up is from a G reg valver rado including a fuse box
Could someone tell me what relay is correct one and where should it be pluged in?
I have everything else working :D
No wander i couldnt find my post in engines section :lol:
Sorry :oops:
anyhow,can anyone help? :help:
Not sure there is a relay for these, fuse is number 10 I think...
Have you tried a new switch?? do you get power to the rear fog light?
The foglights run from a relay which is in the headlight switch - my fogs weren't working but when I replaced the headlight switch they did - the fogs bypass the fusebox AFAIK. Might be worth taking apart an old headlight switch - I can send you my old broken one if I still have it so you know which bit you need?
did not try new switch, but switch was perfect prior to braking the corrado and also was working ok in my other corrado since
No power to front or rear
fogs do run through headlights switch but it is not a relay as such because it doesnt have a coil within it, if you know what i mean
I'm quite sure there should be a relay somewhere as i used to hear it click once you turn the fogs on :?
