Ronan 0 Posted March 9, 2006 Hmm...another day, another problem, this car gets me down sometimes. A couple of times, it seems like there is no boost coming from the charger. The engine revs up, but you can feel there's no boost, and if I dip the trottle a little more, then it boosts. Sometimes the boost will just cut in though, I don't always have to dip the throttle. Does this mean the charger is foofed? It doesn't feel any slower on boost, and it has only happened a couple of times... Quote Share this post Link to post Share on other sites
G60 Bob 0 Posted March 9, 2006 It sounds like the problem i was having with my G60 and proved very hard to diagnose because it was very intermittant in severity. Seemed to behave better when you were very gentle on the throttle. Check the woodruf key in your bottom (crank) pulley isnt worn causing the timing to be constantly altered (slightly) - it is a common problem on G60s. Its actually the reason why i need to rebuild my engine because it damaged the crank when it eventually sheared off at the bolt. Definately worth checking :wink: Close inspection is required because all the timing marks still line up Quote Share this post Link to post Share on other sites
steveo29 0 Posted March 9, 2006 have you got a boost gauge to confirm if there is boost there or not? maybe a slipy belt or a hose starting to leak Quote Share this post Link to post Share on other sites
task 0 Posted March 9, 2006 Quote It sounds like the problem i was having with my G60 do you stll have this problem mate? mine does this also every now and then .. :roll: I always thought it is a lambda issue . Quote Share this post Link to post Share on other sites
kongo127 0 Posted March 10, 2006 It seems like a slippy belt or even a leak from boosted hoses or Intercooler... Quote Share this post Link to post Share on other sites
g60griff 0 Posted March 10, 2006 it sounds alot like the problem ive got, i need to change the lambda probe, stevemac had the same problem and changed the lambda and cured the problem. the part number and price from gsf are here on this link. http://www.the-corrado.net/.archive/forum/viewto ... k&start=45 Quote Share this post Link to post Share on other sites
