dcuk 0 Posted March 11, 2006 Hi, I know im gonna get told to do a search but i have and cant find anything. Ive got my hands on a set of Wiper/Indicator stalks from a mk3 GTI. Just wanted to know if theyl fit ok on my 1989 16v or what modifications will be needed? Cheers! :) Quote Share this post Link to post Share on other sites
quicky1980 0 Posted March 11, 2006 i think they do, the only difference i know is that the wire is longer on the corrado version, so you may need to extend the wiring. someone may correct me on that Quote Share this post Link to post Share on other sites
flusted 0 Posted March 11, 2006 i never had to extend the wiring on mine. You will need to either trim the top part of shroud or buy a late vr6 1 Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 11, 2006 You really need both parts of the late cowling - very cheap from VW Quote Share this post Link to post Share on other sites
wilkes 0 Posted March 11, 2006 i did this as well ,used the one with the hazards from a seat something, which are the same but use the square hazard switch so no need to change the cowling ,hope this helps some one Quote Share this post Link to post Share on other sites
woody 0 Posted March 12, 2006 I did this a while ago, Mine were from a golf which has shorter lead, All I did was chopped off the connector and stripped back (4 x colour coded wires) Than cut the corrado cable so that the connection would be hidden under the dash and then just mated up the wires. Then got the VAG late surrounds and hey presto, I even managed to see the old corrado stalks on ebay with the cable chopped. Cheers Woody Quote Share this post Link to post Share on other sites
flusted 0 Posted March 12, 2006 anyone got part nos for cowling and price? Quote Share this post Link to post Share on other sites
Bobby 0 Posted March 12, 2006 with a bit of fiddling i had managed to have mk3 golf mfa stalks with the early square hazard switch, i made one set from the early corrado and mk3 golf ones. Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted March 12, 2006 i fitted mk3 ones, by cutting wires, was v easy to do, less than ½ hour, even with taking of steering wheel! Quote Share this post Link to post Share on other sites
