Danr 0 Posted March 20, 2006 Ok i remember reading a sticky topic about a certain bolt that causes problems on G60 corrados below all the pulleys, works loose and falls off from what i remember but unfortunately i cant find the post on it and searching doesnt help either, can anyone point me in the right direction cheers dan. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted March 20, 2006 I've got the same problem on my G6016v engine,sounds horrible as if something is going to break loose and fly off i managed to oil all 4 tensioner wheels with a syringe and needle slowly injecting in oil to aid the 14 year old grease and the noise stopped for about a week but then came back with a vengence. Only thing to do in my case is change all the tensioner wheels,a heafty wodge of cash more than certain... Quote Share this post Link to post Share on other sites
steveo29 0 Posted March 20, 2006 danr its the crank bolt that shears off...replace with DX bolt and washer veedubbed, the 8v g60 tensioner wheels are £20 i think from gsf....or you can prise the rubber seal out and grease em Quote Share this post Link to post Share on other sites
Jim 1 Posted March 20, 2006 Are you certain its that fabled bolt? Around this time last year my G60 was making some AWFUL noises from around the g-lader area. I feared the worst and took it in to Stealth for a service it was due anyway.. belts were changed as per the service and the lader was checked - span freely and no apparent problems. With the new belt on it was even worse - sounded like grinding metallic bearings whenever I drove the car, increasing in volume whenever the revs increased. Took it back and swapped for a genuine VAG belt and the problem went never to return.... Quote Share this post Link to post Share on other sites
Danr 0 Posted March 20, 2006 Car lost loads of power, phoned g-werks said it sounded like that bolt had come loose, so thought i would look on here as i remember it being mentioned before. But i couldnt find the information lol Quote Share this post Link to post Share on other sites
Fez 0 Posted March 20, 2006 i got this prob but have no loss of power, im not to clued up when it comes to engines and am fearing that the charger is due a rebuild. Dont suppose one of you know anything about chargers that live in the cardiff area that could have a look or recommend a garage that can. Safe as chuff :D Quote Share this post Link to post Share on other sites
Tempest 0 Posted March 20, 2006 Car lost loads of power, Check the timing marks on flywheel, crankshaft pulley, dizzy and camshaft pulley: Do they still all line up 100%? If not, then yes, your engine timing has gone adrift due to a loose crankshaft pulley. High time to get the old bolt out and replace it with a DX hex-bolt and washer (still have a set, if you need one, left-over from a previous group-buy), don't forget to apply a drop of Loctite 243 Lock&Seal on the bolt before screwing it back in. Tempest Quote Share this post Link to post Share on other sites
Fez 0 Posted March 20, 2006 any help with mine tempest? Quote Share this post Link to post Share on other sites
Danr 0 Posted March 21, 2006 Is the dx bolt the one form a mk1 1.8? Quote Share this post Link to post Share on other sites
Danr 0 Posted March 21, 2006 Apparently all the awful noises are coming courtesy of the charger :mad: Quote Share this post Link to post Share on other sites
Jim 1 Posted March 21, 2006 Uh oh... has the oil feed line blocked up? Quote Share this post Link to post Share on other sites
Danr 0 Posted March 21, 2006 Not 100% sure no holes in casing so will be on its way to gwerks in the next day or so. Quote Share this post Link to post Share on other sites
kongo127 0 Posted March 21, 2006 I know that there´s a nut from the timing belt cover. Once i had that problem i found the nut on the engine bay. The timing belt cover was touching the timing belt and cutting it! Quote Share this post Link to post Share on other sites
Tempest 0 Posted March 21, 2006 any help with mine tempest? You too might benefit from a charger rebuild by Darren at G-Werks, TBH. Quote Share this post Link to post Share on other sites
Fez 0 Posted March 23, 2006 sounds like a plan :lol: Quote Share this post Link to post Share on other sites
