ardandy 0 Posted March 30, 2006 Nearly every modernish car I've driven has had the function, so when you put the car in reverse with your wipers on, the rear wiper will come on automatically. Is this a simple thing to do, or does it mean a lot of tinkering for a little mod? Quote Share this post Link to post Share on other sites
carpy25 0 Posted March 30, 2006 Should be easy you have to take a live feed from the reverse light to the trigger on the rear wiper relay but you need to put in a one way diode so that when you put the rear wiper on (while not in reverse )the reversing lights do not come on long piece of wire and a one way diode plus a few conectors is all you need cheap and not a lot work Rob Quote Share this post Link to post Share on other sites
gsbellew 0 Posted March 30, 2006 To do it right so it only comes on when you have the front wipers on and shift into reverse you would need to use two 4 pin relays. Wired as follows: R1 = Relay 1 R2 = Relay 2 A feed from the reversing lights goes to pin no 86 on R1 pin 85 on R1 to ground pin 30 on R1 to an ignition live feed via an inline fuse pin 87 on R1 goes to pin 30 on R2 Pin 86 on R2 goes to the front wiper relay output Pin 85 on R2 goes to ground Pin 87 on R2 goes to the rear wiper relay input. The above circuit while being slightly more complicated cuts out feedback and means that the rear wiper will only automatically come on with reverse and the front wipers on / on its own switch as normal. Quote Share this post Link to post Share on other sites
