huskerjim 0 Posted April 19, 2006 The speedo digtal reading is on but the it doesn't work when driving the mph doesn't read just stays on 0 the mfa reading is 0 as well the temp gauge doesn't work either, the oil temp does work? Any suggestions? What is the button that lights up on the side of the automatic transmission shifter as well I need help to understand this thing. Help and thx all Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 19, 2006 Welcome to the forum, what car do you have?? For the digital speedo there should be a electronic sender on the top of the gearbox that feeds the speedo... Was £15 to replace on my G60 when it played up but not sure if the auto one is the same or not - probably located in the same place you fill the box up... check it's pluged in and wiring is ok before ordering... Water temp gauge not working?? - your looking for a black plug on a black sender usually located on a plastic flange on the front of the head (depending on engine) and next to a blue one... take plug off and measure resistance across the sender pins, new senders are very cheap from VW Quote Share this post Link to post Share on other sites
huskerjim 0 Posted April 20, 2006 I have a American Sold Corrado 1991 Super Charger Automatic, What I have is the Speedo registers the miles but they no longer go higher they are stuck on the 148k and the temp gauge with needle as well as the digital MFA is registering 0 the tach flickers sometimes? The oil Temp on the MFA works the Time works the outside temp all works on the MFA but the rest reads 0. I hope this gives you an idea of what I'm up against. I really like this car Got it for my Daughter to drive just had the transmission serviced the TM Tech said it all looked good and ran great the motor I tuned up with fresh plug and so forth, the little car needs a little TLC and it will come around I'll be sending it to paint shop next week! Just need some help from a few of you Professional Corrado drivers and tech's who know how to work on these thing, Help me out Guys and Gals.. Jim Reno NV USA Quote Share this post Link to post Share on other sites
