LowG 0 Posted April 20, 2006 Recently changed the G60 wiring loom and fuse box as my fuse box had a melted terminal. Now im having problems on getting the instrument dials to function. The speedo, fuel gauge and MFA function dont work, there is power to the cluster (its a digital one) time and all shows, MFA dosent seem to function. I have checked the wiring but havent found anything out of place. By the way I removed the G60 ecu and wiring loom and installed a 16v one. I have no manual at the moment and cant think of what it could be hmmmm. Quote Share this post Link to post Share on other sites
Karoliz 0 Posted June 21, 2007 Have the similar problem now - cluster was working perfectly, but this morning after starting the car - nothing is working exept cluster light, clock and odometer. What might be the problem? P.S. i've seen similar topic before, but can't find it now :( Thanks ;) Quote Share this post Link to post Share on other sites
Karoliz 0 Posted June 21, 2007 Problem solved - the fuse nr16 was gone.. Quote Share this post Link to post Share on other sites
