MARLBORO_LITE
Will wheels for Civic CRX also fit a Corrado?
As above really, generally speaking, are alloys suitable for the Civic fitment also suitable for the 4 stud Corrado?
Grateful if someone could let me know before 8 o'clock tonight........
Cheers
probably not but you just need to go check the centre bore is the same the one on the corrado is 57.1mm
and also you need to make sure the studs are the same distance apart the corrado one is 4x100
cheers andy
im sure someone will add some before the days out
Thanks fellas. I am worried that the centre bore values are different, albeit 1.1mm. Would this mean the wheels themselves are not firmly sat on the hub? Is this crucial/critical?
Cheers
