iow_corrado_g60 0 Posted May 2, 2006 hi gents just ordered my ps2 adapter and and few little extra bits but what i was wondering was! im going to put to 5" monitors in each head rest! the mounting brackets come with monitor so that not a problem! but what i was wondering was how do you get a signal to go from those monitors to my monitor playstation in the front? Is there a certain reciever i need to plug into head unit front screen to feed the back 2 in sync? Cheers Andy Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted May 3, 2006 hi lads is anyone running a multi tv set up in there car as i think i need one of these to run this http://digitalsounddirect.co.uk/shop/pr ... d/755.html but does anyone know if this means i can have 2 inputs going in from the monitors in headrest and one out put from there to the head unit sorry guys im not too clued up on this! quick update i just spoke to my local safe & sound! and the bloke said i need a video amplifier so the picture doesn't distort! im gonna make a list of things i still need to get later then i'll update you! if any one has any info thou would be greatly appreciated Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted May 9, 2006 hi lads i got my adapter for ps2 today! i want to connect it to the ignition switch anyone got any ideas how to do this! i dont want to take a direct feed off the battery as the ps2 will be constantly on then! any help would be great thanks Andy Quote Share this post Link to post Share on other sites
.A.N.T. 0 Posted May 9, 2006 Can you use a relay attached to the 'amp remote turn on' wire to power the playstation. then when you turn on the stereo it switches the playstation on, otherwise you'll need the ignition on all the time someone is playing which could get well annoying if you want to nip into the garage etc... What I mean is use a relay to turn on a big current from the battery when you turn on the stereo. using just the remote wire to power it will overload the stereo... Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted May 9, 2006 i cant do that i dont think as it has an earth and live wire no single wire to attach to the amp remote wire! but i want to have it on when ignition comes on as thats when i will be using it! otherwise i'll have to have it on standby which means overnight then the car will die! Quote Share this post Link to post Share on other sites
