MNuTz
Passenger door lock problem
Lo all,
Ive been driving my C pretty much solid since i got it a week ago and had no real problems until today.
I took my little bro home yesterday and the passenger door lock worked fine, got home and parked up. Went to go out last night and i noticed a rattle coming from the passenger door but thought it was just the interior squeaking. However, i went to unlock the door today from the inside and nothing. The lock pin comes up about 2/3s of the way and then is pulled back down, i tried from the ouside and the same happens.
Drove about for about 30 mins and thought id try it again as the g/f was climbing out of my door. It unlocked and opened. Locked it and tried to open again. Same problem.
Its currently parked outside, unlocked but i need some advice on what it may be before i start ripping the door cards off.
Central locking doesnt work although im not sure why.
Its sounds like a metal rattle but doesnt happen all the time when driving, it doesnt make a noise at all when still, even if the ignition is on which makes me think that i cant be the central locking trying to work.
Any help would be great!!
Few threads:
http://the-corrado.net/.archive/forum/viewtopic.php?t=40161
http://the-corrado.net/.archive/forum/viewtopic.php?t=39759
http://the-corrado.net/.archive/forum/viewtopic.php?t=31950
http://the-corrado.net/.archive/forum/viewtopic.php?t=23444
http://the-corrado.net/.archive/forum/viewtopic.php?t=20880
There's stacks more and I can't vouch for the ones above, but there is a lot of info already on the forum.
Hope you get it sorted - probably a probem with the vacuum/pump.
