flatg40 0 Posted May 3, 2006 I would like to fit a WI system with a nozzle just after the IC, but should I necessary remove the return pipe to the G-lader ? Can it absorb water, as the flow is cut as soon as the boost is down ? Does anyone here use WI w/o removing the return to the G Lader ? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted May 3, 2006 I've installed teh Aquamist 2d system on mine but I have the boost return removed! - I think most if not all using it have! Quote Share this post Link to post Share on other sites
