.A.N.T. 0 Posted May 8, 2006 My spoiler has given up... Works manually but doesn't go up or down at any speed (up to 100mph, haven't tested above that recently!) It's not the blue/white wire as I've done nothing to the dashboard and it worked fine a while ago. Figure I might try a different control unit. Found one for sale, but it has a different part number. Mine is 535 919 845 A and the replacement I've got is 535 919 845 B Is there much difference between the two? There is between the years, the connections are all different, but I've sent photos and it looks right... Edit: Might be something to do with the resistor? Later models go up at 60 instead of 45? Any ideas? cheers... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 8, 2006 If it physically fits connection wise then I'd try it but the replacement for your original is 535 919 845 C Quote Share this post Link to post Share on other sites
.A.N.T. 0 Posted May 8, 2006 Will give it a go then.... Cheers... Quote Share this post Link to post Share on other sites
gaz1000 0 Posted May 10, 2006 Howdy my Rado has aproblem, the speedos circuit board cooked itself and no dials workd so i went to Ebay and got a used one. with 177000 miles on it.mines got 122000 on it.is it possible to change the digi clocks with out causing ne problems to the circuit board???? Quote Share this post Link to post Share on other sites
