quicky1980
Auto Closure
just converted my sunroofs 3 wire control to 6 wires. got it working fine, just need to wire the auto closure wire up to my car.
Which wire do i need to attatch this to? Im guessing theres an auto close feed that comes from the central locking, but i dont know which one this is.
also which wire tells the central locking to supply the auto close feed?
thanks
doesnt anyone know which wire comes from the central locking to operate the auto close feature on the windows/suroof?
:fadein:
Dont know what the colour code is, but you will be able to find it coming from the drivers door loom.
Take a look, it will be attached to the door handle ultimatly as the holding of the key in the lock activates the sunroof closure manually...
Turn the key in the lock and stick a meter or test light on the wires which come off it, im sure youll figure it out in less that a minute...
or someone who knows the colour code could save a bit of playing around....
as said above, most simple way to find it out would be to stick a meter across it when you are holding the key in the lock position
