quicky1980 0 Posted May 10, 2006 just converted my sunroofs 3 wire control to 6 wires. got it working fine, just need to wire the auto closure wire up to my car. Which wire do i need to attatch this to? Im guessing theres an auto close feed that comes from the central locking, but i dont know which one this is. also which wire tells the central locking to supply the auto close feed? thanks Quote Share this post Link to post Share on other sites
quicky1980 0 Posted May 19, 2006 doesnt anyone know which wire comes from the central locking to operate the auto close feature on the windows/suroof? :fadein: Quote Share this post Link to post Share on other sites
Steve B 0 Posted May 25, 2006 Dont know what the colour code is, but you will be able to find it coming from the drivers door loom. Take a look, it will be attached to the door handle ultimatly as the holding of the key in the lock activates the sunroof closure manually... Turn the key in the lock and stick a meter or test light on the wires which come off it, im sure youll figure it out in less that a minute... or someone who knows the colour code could save a bit of playing around.... Quote Share this post Link to post Share on other sites
Guest Posted May 26, 2006 as said above, most simple way to find it out would be to stick a meter across it when you are holding the key in the lock position Quote Share this post Link to post Share on other sites
Kick Up The Rs 0 Posted May 26, 2006 Just wired in an alarm & IIRC the centrol locking close wire is red/yellow located just to the RHS of fusebox going into door loom. Quote Share this post Link to post Share on other sites
