Holmes 0 Posted May 18, 2006 Finally got my car on the road after 6months and the stereo starts playing up. Basically, it will work when the engine is turned off, but as soon as i start her up, i lose all power to the headunit. I cant physically see anything wrong with the connections, anyone had this problem or know of any solutions? All suggestions would be appreciated, cheers Jon Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted May 18, 2006 Hmmm.. I'm sure mine had similar symptoms last year - new ignition switch fixed it Quote Share this post Link to post Share on other sites
_Monkey 0 Posted May 18, 2006 Sounds like a dodgy switched live (red wire). Like joebloggsVR69 said, probably your ignition switch. Happy Birthday by the way!! :new-bday: Quote Share this post Link to post Share on other sites
Holmes 0 Posted May 18, 2006 thanks. Either of you know how to change this to get it sorted? is it something i can do myself fairly easy. Cheers for the bday shout g60dave Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted May 18, 2006 You can change it yourself, but getting to it's a bit tricky. New ignition switch is ~£25 from VW. Dont buy a crappy GSF one!! You'll need a long thin screwdriver (jewellers type, Halfords, Homebase etc sell them) The screw is a b4stard to get to, so good luck! :) There's a guide here: http://www.the-corrado.net/wiki/index.p ... eplacement Quote Share this post Link to post Share on other sites
_Monkey 0 Posted May 18, 2006 Or I always wire the switched live off the same as the permanent live (yellow). You have to switch off the stereo when you're done, but you can have it on when the key's not in. Quote Share this post Link to post Share on other sites
Holmes 0 Posted May 19, 2006 Thanks for the help guys, il give it a shot at the weekend :? Quote Share this post Link to post Share on other sites
