ardandy
Rev Lights
Is this possible?
Stole the pic from another post as its perfect to illustrate my idea.
Basically, using the four blanked LED spaces on the right, fill them all with LED's and using fancy electrics (and jiggery pokery) get them all to light up when you approach the rev limit. Like a change light.
is that not wot the other guy has done? :?
It is indeed, Riley has done it using an Omex shift light
Is it possible to do it so they're all off, and then when you get to say 750rpm before the red line, all four light up? As opposed to a progressive one?
course
just wire up the wires which power the 750rpm light and wire it up to the other leds.
Is there a 750rpm light? Where abouts is this?
