woody 0 Posted September 20, 2003 Ok blower only working on 4. Does this mean that thermal resistor has blown time to ring Maplins. Also do any other VW use the same kind of resistor / blower setup Golf! (3 speed only) Passat????? Quote Share this post Link to post Share on other sites
Guest Posted September 20, 2003 mines fooked too, only works on 4. whats the value of the resistor, if that is the problem? Thera Quote Share this post Link to post Share on other sites
dan 0 Posted September 20, 2003 I think they're about £20 from the dealer. Quote Share this post Link to post Share on other sites
Rado16v 0 Posted September 20, 2003 Hi, here's a great write up: Heater blower fix be sure to try the bit at the bottom first, that fixes most of the probs. HTH Amit Quote Share this post Link to post Share on other sites
dan 0 Posted September 20, 2003 Hi, here's a great write up: sure is Amit 8) Quote Share this post Link to post Share on other sites
Furkz 0 Posted September 20, 2003 USE THE write up i did only cost me 79p from maplins i have the product code at home if u guys getting probs PM me and i will sort out the code 2mrow if u need....IT WORXS by the way and u dont even have to solder it LOL Good Luck also CHEERS AMIT Quote Share this post Link to post Share on other sites
vr6storm 0 Posted September 20, 2003 Hi, here's a great write up: sure is Amit 8) that write-up helped me get my blower working on all 4 speeds within an hour of taking the interior apart :D Quote Share this post Link to post Share on other sites
Guest Posted September 22, 2003 any chance of posting that product code FurkiG60? I'll order it today, and do it in my lunch break tomorrow :D Thera Quote Share this post Link to post Share on other sites
Rado16v 0 Posted September 22, 2003 Glad to hear it helped guys. Great write up written by Jason Hughes. Quote Share this post Link to post Share on other sites
Guest Posted September 22, 2003 hmmmz, after reading the bit at the bottom (as amit said), I have fixed it, The small contact that turns with the knob needed to be adjusted (bent), it wasn't making full contact with the other two contacts so I just bent it so it made a proper contact with the two plates, and now it works fine :D \o/ Thera ps, cheers again amit mate, saved my life again :) Quote Share this post Link to post Share on other sites
woody 0 Posted September 24, 2003 Fixed the blower with the help of RA16C 184 oC resistor from maplins in bournemouth. Cheers all for advice. Quote Share this post Link to post Share on other sites
