woody
Blower Only Working On 4
Ok blower only working on 4. Does this mean that thermal resistor has blown time to ring Maplins. Also do any other VW use the same kind of resistor / blower setup Golf! (3 speed only) Passat?????
mines fooked too, only works on 4.
whats the value of the resistor, if that is the problem?
Thera
USE THE write up i did only cost me 79p from maplins i have the product code at home if u guys getting probs PM me and i will sort out the code 2mrow if u need....IT WORXS by the way and u dont even have to solder it LOL
Good Luck
also CHEERS AMIT
Hi,
here's a great write up:
sure is Amit 8)
that write-up helped me get my blower working on all 4 speeds within an hour of taking the interior apart :D
any chance of posting that product code FurkiG60? I'll order it today, and do it in my lunch break tomorrow :D
Thera
hmmmz, after reading the bit at the bottom (as amit said), I have fixed it, The small contact that turns with the knob needed to be adjusted (bent), it wasn't making full contact with the other two contacts so I just bent it so it made a proper contact with the two plates, and now it works fine :D \o/
Thera
ps, cheers again amit mate, saved my life again :)
Fixed the blower with the help of RA16C 184 oC resistor from maplins in bournemouth. Cheers all for advice.
