Colley 0 Posted June 26, 2006 Hi guys, My 95 VR6 has intermitent problems in that sometimes it doesnt fire? Was going fine then the other day it just decided it didnt want to start, its been like this over the weekend though at some points it does start? Obviously Vag-Com would be a good start but i dont have it and no one in the area does. The spark plugs and leads are about a year old so shouldnt be related to that i wouldnt have thought? Any suggestions would be appreciated as its one thing after another!! :mad: Quote Share this post Link to post Share on other sites
ardandy 0 Posted June 26, 2006 Check plugs for oil deposits etc? Quote Share this post Link to post Share on other sites
bcstudent 0 Posted June 26, 2006 My friend's '93 Corrado VR6 used to do this. For example, he'd drive to work with no problems then it'd refuse to start when he was leaving for the day. By the time the RAC turned up it'd decide it was ok again. Bloody annoying. I can't remember exactly what the problem was but he spent a lot of money looking for it. I'll ask him later. Quote Share this post Link to post Share on other sites
buttles 0 Posted June 26, 2006 If you can get to the Redhill area then I can help you out with Vagcom Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 26, 2006 sounds like a temp sensor to me.............but VAG-COM is yer best bet Quote Share this post Link to post Share on other sites
Niges16V 0 Posted June 26, 2006 na, it's the ECU relay! Quote Share this post Link to post Share on other sites
stu200 0 Posted June 26, 2006 hi ive recently just bought my 95 vr6 and mine had the same problem!! :x got it plugged in and it turned out to be the (crank reference sensor). Got a new one put in and bobs your uncle it was fixed. The sensor costs about £140 though :roll: stu Quote Share this post Link to post Share on other sites
Henny 0 Posted June 26, 2006 faulty ignition switch? Does it turn over and over but never fire? Is there voltage to the coil/coil pack while cranking? Quote Share this post Link to post Share on other sites
