daytona600 0 Posted July 8, 2006 how long before that newbie tag gets changed? been a member for over a year now :-( Quote Share this post Link to post Share on other sites
nickeboy 0 Posted July 8, 2006 there is a fuse above the relays on mine, it is a pain to get to but it is there, there is suppose to be anouther fuse for the abs but i will be damned if i can find it,, of you find it then post it up here because it seem to cause alot of people problems finding it, if that does not work then vagcom is the way forward, 40 quid from any vdub specialist! nick Quote Share this post Link to post Share on other sites
daytona600 0 Posted July 8, 2006 Thanks Nick, I have read about the fuses above the realys in my handbook & the factory manual but I am dammed if I can find them. If I get a chance I will post a picture of my fuse box later. Another Nick Quote Share this post Link to post Share on other sites
daytona600 0 Posted July 8, 2006 just found a vagcom cable & software on eBay for £13 has anyone bought one of these? is it worth purchasing? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 8, 2006 how long before that newbie tag gets changed? been a member for over a year now :-( You need to post more i'm afraid dude! :lol: I think it changes to 'regular' when you hit the 100 mark... ABS relays are up behind the glovebox... Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted July 9, 2006 Was looking up behind the glove box this morning, all i can see is two relays no. 79 and 179 ones grey the other black and below that are two fuses. so is there another fuse further up that i'm not seeing? Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted July 9, 2006 Supercharged, Right Findings!!! Male Drivers Side Front: 4.089 ohms Drivers Side Rear: (starts to read up to 4 then reads 0)?? Passenger S F : 4.000 Passenger S R : 3.900 Female DSF: 1.079 ohms DSR : 1.08 PSF : 0.0?? PSR : 1.08 Again any help would be appriciated, take it passenger front is knackered but whats with DSR? Cheers AJ Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted July 9, 2006 just found a vagcom cable & software on eBay for £13 has anyone bought one of these? is it worth purchasing? Looks alright for £13, says you can return it if you ain't happy too! Only problem for me is it says on the application list that it doesn't work for G60 ABS :cry: Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted July 9, 2006 got some read outs too, Male Drivers side front: 4.16 drivers side rear: 6.28 passenger side front: 6.28 passenger side rear: 6.28 Female DSF: 0 DSR: 1.081 PSF: 0 PSR: 1.085 sorry to keep thread jacking, any help would be great, i'm taking it that the two front sensors are away but what does the DSF male reading of 4.16 mean??! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 11, 2006 Guy's, I'm fairly sure it's the female readings you need to look at and once you've conformed the physical connection is ok, change the sensors... The other readings are bassically looking at the ABS ecu - no idea on the relevence of these and may just be different because of cable length... I wouldn't worry for now as both of you have dead sensors... Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted July 11, 2006 Cheers Supercharged, Going in to the garage for sensor tomorro so will let you know how it goes, hope it works, MOT runs out friday! Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted July 13, 2006 Sensor been replaced, light still on, what the feck? Quote Share this post Link to post Share on other sites
nickeboy 0 Posted July 14, 2006 maybe the abs needs resetting, i think the newer models have a memory? Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted July 14, 2006 Thing is cars been on 2 different computers and not one of them can read the car, or the car won't let them for some reason, thats why i'm fully stuck! Quote Share this post Link to post Share on other sites
NottsCounty 0 Posted July 14, 2006 Hi guys, just thought i'd add my two penneth worth in here to try and really throw you off the scent. When I got my 92 VR the ABS light was doing some funny things staying on, flashing, on and off intermittently. Took it to the garage and VAGCOM threw up a dead sensor so thinking all was fine I drove off........ Only for the ABS light to come on and STAY ON for the whole drive home!! This carried on for some weeks so I decided to have a look myself and in the end I took the ABS rings off from inside of the rear discs (bit of a bitch to do!!) gave them a good clean up and re-fitted them. ABS light now comes on at startup and then goes off and stays off!! WooooHooooo, but.........just my thoughts and personal experiences. Your's may well be different. Give it a go and good luck boys Quote Share this post Link to post Share on other sites
daytona600 0 Posted July 16, 2006 worth a try, Thanks. Quote Share this post Link to post Share on other sites
