Fez
Headlamp prob
Not sure they would go to a relay. Fuse positions however are.
Fuse 1 = H/light low beam, left.
Fuse 2 = H/light low bem , Right
Fuse 11 = H/light High beam, left
Fuse 12 = H/light High beam, Right
reason being a garage changed my gear box and they took the battery out to charge it. when they clamped the battery back in they clamped the passenger side headlamp loomp with it.
When I turned the main beam on I was greeted with a big cloud of smoke and only side light action. Full beam does not work either.
I've since re wired the headlamps back to the fuse box and all fuses are fine.
So i think either:
The fuse box is fooooked
The lamps are connected to a relay in some way and thats foooked
or the on dash sidelight/main beam is foooked.
Any suggestions gang? Any help greatly apprieciated.
yeah but it was a while back and i lost my receipt. GRRRRRRRR
any otha answers.
Receipt? They should have records of what work has been done on their customer's cars...
It could have done the headlight switch or the dip switch on the column as well during your burnout.
Have you done continuity checks through the system with a voltmeter?
Gavin
