Fez 0 Posted July 7, 2006 Does anyone know which relay controls the headlamps in a 91 C??? Quote Share this post Link to post Share on other sites
560 0 Posted July 7, 2006 Not sure they would go to a relay. Fuse positions however are. Fuse 1 = H/light low beam, left. Fuse 2 = H/light low bem , Right Fuse 11 = H/light High beam, left Fuse 12 = H/light High beam, Right Quote Share this post Link to post Share on other sites
Fez 0 Posted July 7, 2006 reason being a garage changed my gear box and they took the battery out to charge it. when they clamped the battery back in they clamped the passenger side headlamp loomp with it. When I turned the main beam on I was greeted with a big cloud of smoke and only side light action. Full beam does not work either. I've since re wired the headlamps back to the fuse box and all fuses are fine. So i think either: The fuse box is fooooked The lamps are connected to a relay in some way and thats foooked or the on dash sidelight/main beam is foooked. Any suggestions gang? Any help greatly apprieciated. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted July 8, 2006 Get the garage to sort it for you- it was their fault! Quote Share this post Link to post Share on other sites
Fez 0 Posted July 9, 2006 yeah but it was a while back and i lost my receipt. GRRRRRRRR any otha answers. Quote Share this post Link to post Share on other sites
VR6 0 Posted July 9, 2006 Receipt? They should have records of what work has been done on their customer's cars... Quote Share this post Link to post Share on other sites
h100vw 0 Posted July 9, 2006 It could have done the headlight switch or the dip switch on the column as well during your burnout. Have you done continuity checks through the system with a voltmeter? Gavin Quote Share this post Link to post Share on other sites
Fez 0 Posted July 9, 2006 cheers dude, will check this 2 mo :D Quote Share this post Link to post Share on other sites
