DUBVR6 0 Posted July 12, 2006 Guys, Just come back from no rice and when i do over 60 mph, i start to hear a hissing noise from the dash area??? Can't pinpoint it???? Help please Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 12, 2006 Had a new windscreen recently? Quote Share this post Link to post Share on other sites
DUBVR6 0 Posted July 12, 2006 had a new screen put in, but checked all the seals looks fine Quote Share this post Link to post Share on other sites
M15 VW 0 Posted July 13, 2006 where abouts on the dash is it coming from, can u tell? Quote Share this post Link to post Share on other sites
White2505 0 Posted July 13, 2006 is your mfa still working? check the vacuum line to back of the dash has'nt fallen off. Quote Share this post Link to post Share on other sites
Guest Posted July 13, 2006 Had a new windscreen recently? you think they may have fitted a snake behind the dash whilst they did the windscreen? Quote Share this post Link to post Share on other sites
DUBVR6 0 Posted July 13, 2006 lol Gta watch out incase the snake crawls up me trousers ;) its coming fom the drivers side dash and u can only hear it once it hits over 60mph hw u check the vacumn thingy and will dat make a noise after 60mph??? Quote Share this post Link to post Share on other sites
White2505 0 Posted July 13, 2006 take the housing off under the dash board so you can lie in the footwell and look up behind the steering column. Black rubber pipe should be plugged onto back of instrument binacle. if you start the engine up with the housing off and rev it up a bit you should hear it. Main thing before removing anything is whether the mpg thingy on your mfa is working. if it is it wont be the vacuum pipe. Quote Share this post Link to post Share on other sites
DUBVR6 0 Posted July 14, 2006 cheers lads, il check that tonite. is there nething else i should check for Any suggestions???????????? Quote Share this post Link to post Share on other sites
