flusted 0 Posted August 6, 2006 Ok,done it and it runs fine and goes alot better!!! 8) Does this mean that both lambdas i tried are no good? Will i cause any probs driving it with wot switch taped on? Also exhaust is quieter on idle and theres no hissing from isv breather? Quote Share this post Link to post Share on other sites
flusted 0 Posted August 16, 2006 Update. Bought brand new lambda and fitted today,but problem is still there when lambda is wired up. So still running without lamda and switch taped What could it be? Quote Share this post Link to post Share on other sites
HVB G60 0 Posted August 21, 2006 Did you check your FPR? These things fail sometimes, causing all kinds of problems, one of those being that your engine gets way too much fuel. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted August 21, 2006 How are you wiring the lambda ? have you Eathed it correctly. Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted August 21, 2006 i agree. id double earth it. what shows on a af gauge. does it cycle then go back to warmup - broken power wire. bad signal - get a lean signal - bad earth or signal wire. car will chug more and more as time goes on over a minute or so period. lean signal tells injectors to put more in making more chug... i had a universal in and it wouldn't hold properly. in the end i got a full probe and wiring to 4 pin plug from vw and fixed the issues on the car harness side. thats the weak side usually. Quote Share this post Link to post Share on other sites
DUB 0 Posted September 5, 2006 BUMP .......................... results needed :lol: :oops: Quote Share this post Link to post Share on other sites
flusted 0 Posted September 6, 2006 Lambda is wired ok,getting voltage on purple wire at ecu ranging from 0.30 upto 0.80 on idle so the lambda is working. If i unplug lambda, car runs even worse,ive resorted back to the taped switch as the car flys with this done :lol: Darren suggested i try another ecu, but where would i find one on the Isle of Wight? :scratch: :help: :norty: Quote Share this post Link to post Share on other sites
g60griff 0 Posted September 6, 2006 aide il send you that ecu, whats the part number on your ecu now. Quote Share this post Link to post Share on other sites
DUB 0 Posted September 6, 2006 flusted said: Lambda is wired ok,getting voltage on purple wire at ecu ranging from 0.30 upto 0.80 on idle so the lambda is working. If i unplug lambda, car runs even worse,ive resorted back to the taped switch as the car flys with this done :lol: Darren suggested i try another ecu, but where would i find one on the Isle of Wight? :scratch: :help: :norty: Flust - but hoe htf do you do that taped switch thing - cheers mate :wink: Quote Share this post Link to post Share on other sites
flusted 0 Posted September 6, 2006 undo the 2 screws that hold the switch in,then tape it so its pressed all the time,then unplug lambda. Heres a pic of my switch,i cable tied it so it stays pressed Quote Share this post Link to post Share on other sites
g60griff 0 Posted September 11, 2006 so if this works with this set up, what is wrong with the car. Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted September 11, 2006 griff i think its the ecu thats knackered aide said he doesnt think its taking to the new lambda as lambda is reading but then not doing anything so he thinks it can only be a problem with fueling from the ecu! Quote Share this post Link to post Share on other sites
flusted 0 Posted September 14, 2006 *update for reference* Ive now got another ecu fitted (thanks griff!)and seems slightly better but prob is still there. Ive now tested the throttle position switches and they are both working,ive ran another earth wire from battery to side of head and have 0.00 resitance at the earth points when engine is cold but it creeps to about 0.06 when warm. It idles loverly now but is very hesitant between 1-2k and if i floor it, it just bucks and hesitates. light throttle and its ok. I dont have an ecu holder so was worried that the ecu needs to be earthed so have ran another wire from ecu body to bodywork. Im going to try running the car with throttle switches unplugged tommorrow to see what effect this has. co pot is set to 500ohms but might try setting to 800 next will post results Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 16, 2007 Flusted - what did you do with this evenually?? Quote Share this post Link to post Share on other sites
flusted 0 Posted December 17, 2007 It was actaully running lean i guess, chenged the fpr when fitting the red tops and totally cured the problem 8) Quote Share this post Link to post Share on other sites
