m3evo
G60 Sparkplugs
just picked up a set of Beru plugs from GSF this morning... They're the Polo G40 ones and came in at a whopping £2.43 each to me! :lol:
Just got to change the fuel pump, filter, plugs, dizzy cap and rotor arm and see if that's gonna get her running on 4 cylinders again... 8)
:oops: got halfords ones on at the moment :oops:
I hasten to add, not through choice, they were the only ones I could get to prove that they weren't the problem in the first place... the genuine ones I was using will be going back on along with these plugs... 8)
so all G60'S run Platinum plugs ?
its just my car has had 3 prongs fitted at the last 4 services at 3 places (before i got the car)
Yep - they are a fiver from VW, cheaper than the sixes...
When i tried to buy some 6's from my local stealers, they wanted to charge me £60 for 4 spark plugs.
I told em them i didnt think so!
I think i may get some 5's. Thanks for the thread and info people. :notworthy:
Shaggsy, well if you think the W5DP0 are cheaper, you might want to think again
You can get cheaper plugs that will work, but they wont work as long, so you'd be better off with some platinum plugs. They normally last 3-4 times as long as copper plugs
Hello Folks,
Anybody where I can get a set of W5DP0 plugs from struggling to find a supplier.
Thanks for any help in advance
Hello Folks,
Gwerks
