gollfy
someone with etka??
Can someone just look what this part number refers to
811 907 384B
I know its an engine control unit, just need to know which car its from.
its down as being a 'control unit for fully electronic ignition' for a KR engined golf or jetta 1986-88. part no superseeded by 811 997 384x
hth
baz
Can you possibly do me an exploded boot view and numbers? I've bust the monkey metal connector between the release button and the mech on the boot and the local "specialists" can't locate a number for it!
'Monkey Metal' - love it :lol:
There you go - easy enough to find on the 'tailgate' page - muppets :roll:
18 is the bit that usually breaks but when I did mine I also had to replace the clip 18a which it says is no longer available and it didn't comes as part of 18 either... also note the white ball socket clip number 20, worth getting this too...
Hi matey, thanks for that but the rod and ball clip are there I think it'll be either 11 or 13 but can't see them on the list?
yeah think so I've just taken these photos to see if it makes things easier.
100_0263.jpg shows broken part, bit that's attached to lock plate and is pivoted on the left
100_0261.jpg shows remaining piece of above (rest shattered)
100_0262.jpg This I assume ties the lock and central loking together some how? (found in the tailgate cavity lose.
