Baz2004
Oil switch
Can anyone help me with the part no on this oil sensor?
It’s an early 16V KR 1.8 engine, cant get a part no/details on my version of etka.
the part number is on it!
to be fair it's difficult to see, underneath and needs cleaning to read often, but it's a standard black top oil pressure sender (not temp), if you need one I've got a couple from my KR sat in a tub in the garage.
David.
Its tricky to see it with everything back together, I didn’t want to go taking it off to find the part no cus its working Ok I think its weeping a bit of oil so I want to replace it.
Id rather have the part no going into GSF/VW cus I’ve been given the wrong switches in the past without part nos.
should be 068919081 oil pressure switch 1.4bar 1 pin black
if it's leaking from it's washer nip it up a bit more, if it's leaking from the top replace it before it pisses oil out :)
GSF:
93447 OIL PRES SWITCH VW/AUDI PETROL ENGS 98> 1 PIN BLACK(1.2>1.6 BAR) 4.50
That is the high oil pressure switch.
The black type which triggers at 1,4 bar has part no. 068 919 081.
The gasket ring is part no. N 013 811 5, according to ETKA.
