davecash
Went through a big puddle
went through a big puddle last night and my electrics seem to have suffered. the car dies unless the throttle is wide open and will only accelerate with full gas.
other than spraying everything with wd40, any ideas. its a 2.0 16v K plate btw.
thanks!
i did the same last night to, car was very lumpy and didnt want to pull. drove to work this morning an felt fine tho!!
I would have thought you'd need to clean out all of the idle valve and dizzy.... Clean the spark plugs out to, they be contaminated!!!
it takes along time for everything to dry out properly... is soaked mine by mistake whilst cleaning the engine bay took a week to run right again!!!
cheers everyone! i think i'll try spraying a bit of wd40 on everything and hoping the sun has dried up all the rain a little bit.
other than that, i'll be hitching a lift home!
just a quick update if anyones interested:
car still wouldnt idle right the next day, so i disconnected the battery, left it for 10 mins, reconnected and what do u know....it worked!
