iow_corrado_g60
help with offset please guys
Offset is really high (vauxhall offset?) but that's easily cured with some spacers, I know ET 40 will fit without fouling, and my mate was running ET20 7x15's on his G60 with no problems so you should be OK, and if you have any probs you'll just have to space em out a bit!
ET50 won't fit without fouling inners of susp / brakes etc. ET40 is really the limit as slangwerks stated above, spot on is ET35 as you know. Just get some 20mm hubcentric spacers and job done mate. Or buy some really nice polished Borbet C's with the correct ET35 offset......;-)
