bennyd
RSR Outlet and Intercooler
Hi,
I will be soon fitting a Golf G60 intercooler to my corrado G60 and I was wondering if an RSR style outlet (straight one) with a 135deg bend on it will fit (rather than the bend that the Golf uses). I can see that there isn't much room between the charger exhaust and the radiator fan. I'm going to port the charger outlet and the porting all depends on the outlet size, the bigger the better!
Cheers.
you can port the outlet of charger 6mm more if using an rsr outlet.
Im using an rsr with 90 degree samco reducer to my front mount
Which RSR outlet are you using, pics below
or
I would perfer to use the second one because of the larger inlet but with a 135 deg elbow on it I think it'll be to long and rub against the radiator fan.
Have you and pics of your setup.
