wilson 0 Posted August 11, 2006 I'm sure I'm missing something... In the haynes manual it looks like there should be a tube sticking up where the mixture screw is, mine is just a hole, and I'm sure there isn't a screw in there. difficult to see in there though. Quote Share this post Link to post Share on other sites
Henny 0 Posted August 11, 2006 some have a tube, some haven't and some have had it snapped off... There's an allen headed bolt down there (4mm IIRC) to adjust the mixture... Quote Share this post Link to post Share on other sites
wilson 0 Posted August 11, 2006 There's an allen headed bolt down there (4mm IIRC) to adjust the mixture... Oh, I'd done a search on here and 2 seperate posts said 3 mm... maybe thats why I cant turn anything... will give it another go tonight with a 4mm anti clockwise to lean ???? Thanks for response. Quote Share this post Link to post Share on other sites
Henny 0 Posted August 11, 2006 can't remember if it's clockwise or anticlockwise to be honest... :oops: It's been a while. Quote Share this post Link to post Share on other sites
wilson 0 Posted August 11, 2006 :oops: It's been a while. Sorry to hear that, but i'm more concerned with my mixture at the mo..!! Cheers mate. Anyone know, i cant find it in the haynes, although I am using the golf 16v manual Quote Share this post Link to post Share on other sites
Henny 0 Posted August 11, 2006 should be the same... the metering head is the same on Golf and Corrado KR engines... Quote Share this post Link to post Share on other sites
wilson 0 Posted August 11, 2006 should be the same... the metering head is the same on Golf and Corrado KR engines... I thought so cheers Quote Share this post Link to post Share on other sites
bcstudent 0 Posted August 11, 2006 I believe it is a 3mm Allen head. Turn it clockwise to richen and anti-clockwise to lean. Quote Share this post Link to post Share on other sites
wilson 0 Posted August 11, 2006 I believe it is a 3mm Allen head. Turn it clockwise to richen and anti-clockwise to lean. I tried 3mm after searching on here, but put it in the hole and it doesn't seem to locate anything, I've looked in the hole with a torch, and doesn't look like there is a screw there !!! Quote Share this post Link to post Share on other sites
