kasman21
coilover problems i think
Hey guys
my rado is pulling to the left, i have exhausted many areas but i think the coilovers might be setup slightly higher on one side. what is the best way or the only way to check and amend so that they are perfectly balanced.
Causing wierd uneven tyre wear! any advice would be great,. cheers guys
Park it on flat ground and measure from the ground to the top of the wheel arch to see if it's level. Uneven tyre wear and pulling left is more likely to be because the alignment needs adjusting, or the tyres aren't inflated correctly.
Who fitted the coilovers? Did you do it yourself?
Where htey properly aligned after fitting. If not then you need to get a decent 4 wheel alignment carried out to get all of hte car geometry set up right again. Any good garage or body shop should be able to do it, though a lot of people use Stealth or AmD also...
If your going to get it done, make sure your happy wit hthe ride height first, as when you alter the ride height you have to get the geometry re-set....
Setting up the geometry is NOT something you can do yourself....
