kasman21 0 Posted August 21, 2006 Hey guys my rado is pulling to the left, i have exhausted many areas but i think the coilovers might be setup slightly higher on one side. what is the best way or the only way to check and amend so that they are perfectly balanced. Causing wierd uneven tyre wear! any advice would be great,. cheers guys Quote Share this post Link to post Share on other sites
steve_16v 0 Posted August 21, 2006 Park it on flat ground and measure from the ground to the top of the wheel arch to see if it's level. Uneven tyre wear and pulling left is more likely to be because the alignment needs adjusting, or the tyres aren't inflated correctly. Quote Share this post Link to post Share on other sites
kasman21 0 Posted August 21, 2006 what is the ideal tyre prssure for 205/40/17's??? Quote Share this post Link to post Share on other sites
steve_16v 0 Posted August 21, 2006 just did a quick search, the general consensus is 34 front and 32 rear on 17s Quote Share this post Link to post Share on other sites
kasman21 0 Posted August 21, 2006 if i do need to amend the coilovers how do i do it?? i have ner done it before. cheers Quote Share this post Link to post Share on other sites
mbaker8v 0 Posted August 21, 2006 Who fitted the coilovers? Did you do it yourself? Where htey properly aligned after fitting. If not then you need to get a decent 4 wheel alignment carried out to get all of hte car geometry set up right again. Any good garage or body shop should be able to do it, though a lot of people use Stealth or AmD also... If your going to get it done, make sure your happy wit hthe ride height first, as when you alter the ride height you have to get the geometry re-set.... Setting up the geometry is NOT something you can do yourself.... Quote Share this post Link to post Share on other sites
