flusted
Wiring Toad ai606
I just had a bash at fitting a toad ai606.
Ive got it all working except the door locking and total closure.
Ive used the search and found that theres 1 wire that i can use on the corrados loom that will lock the doors and shut the windows all at once.
What colour is this wire,and where can i find it?
Other problem i have is the output wire for the total closure pulls low to ground(less than 3v).
Ive read i need to add a relay but how do i go about this as relays normally switch positive?
Any help much appreciated as my car is sat outside unlocked as car is delocked :oops:
I fitted my toad ai606 alarm and managed to get everything working. Although didnt attemp auto closure.
I found the instructions to fit online, if you havent got it how the hell did you know what you where doin in the first place?
Ive got that pdf document! i dont understand the "pulls low to ground" i need 12v to lock and unlock?
It says about installing a relay,someone must of done this?
you on about c/l?
if i remember correctly i used the possitive trigger locking diagram for wiring up the c/l
im sure that the auto close wire (poss white if i remember correctly) is possitive when engaged
add me to msn if you want and i may be able to work it out with you
you on about c/l?
Can anyone confirm that the corrado is the Positive Trigger Mech?
Ive finally sussed it, you need psitve to red/yellow wire by door.
You need to wire a relay so it switches polority, i have diagrams if you get stuck
is that wire just for the C/L or C/L and total closure??
as i still haven't done my C/L trip.
