aussieg60
Engine loom wiring/connectors question
I have an engine wiring loom from a 89 G60 Corrado. I am installing the G60 engine in my 1990 8v Digi2 Golf GTI. The loom that leads up to the ECU has 2 seperate wiring connectors in parallel that I dont know where they go. My Digi 2 also has 2 connectors different to the G60 loom and I dont know how to retrofit the G60 loom into my car. Does anybody know these connectors and what they do ?
The G60 loom below (the 2 connectors I am questioning)
The Digi 2 loom below. (1 connector goes to the transistorized ignition circuit mounted on a heat sink on the ECU bracket holder)
Looks like your MAF conector and maybe the Lambda probe too ???
Im sure someone will be along later to tell ya. Good luck.
Do the G60's use the TCI-h or is it within the ECU ?
I also find the G60's ECU doesnt fit in the ECU bracket/holder as the heat sink is larger and the vacuum connector is sticking out.
