andybg40 0 Posted September 30, 2006 I appears that my heater control bulb has given up. Or could it be a fuse? Is this on a seperate fuse to the rest of the console or is it definately the bulb. Had a quick look and could not see it, do i have to completely strip down the controls? Thanks Quote Share this post Link to post Share on other sites
Niges16V 0 Posted October 1, 2006 It'll be the bulb. I think it is housed in the centre control knob, carefully pull that off (you need to push the lug in at the bottom) and there is a little green plastic holder with the bulb in. It uses light pipes to illuminate the other bits which is why it isn't all that bright. Quote Share this post Link to post Share on other sites
andybg40 0 Posted October 1, 2006 Have also noticed that the valet light on the passenger sun visor does not work either, could this be connected? Quote Share this post Link to post Share on other sites
Niges16V 0 Posted October 1, 2006 why can't it be the obvious?? It's not a Fiat or Renault you know! Quote Share this post Link to post Share on other sites
andybg40 0 Posted October 2, 2006 why can't it be the obvious?? It's not a Fiat or Renault you know! Am i missing something? :oops: Quote Share this post Link to post Share on other sites
andybg40 0 Posted October 5, 2006 Ok, i have replaced the bulb and still no luck. Also noticed that the ciggy lighter bulb is not illuminated either. All of the fuses are ok, can anyone help? Thanks Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 5, 2006 I had this on my G60, valet light stopped working, so did the interior light and also the cig lighter and illuminating light. Its not always obvious that a fuse has blown, could be an hair line break. Have you changed the fuse yet? Quote Share this post Link to post Share on other sites
andybg40 0 Posted October 6, 2006 No not as yet. Although i am starting to think that there maybe a problem with the feed to the bulb as the actual heater works fine. Has anyone ever changed the heater controls. Looks simple enough, just remove and re-attach the cables? Cheers Quote Share this post Link to post Share on other sites
