H8RRA 0 Posted October 6, 2006 ...been offered a rather tidy a3 18t sport for the wife to run about in ( well, when I need to drive it, i'd rather she had something smart ;) ) it's a good price - but - has clocked 150k with full VAG history stamped to 130k Any advice on these motors etc would be appreciated as i'm going to look at it this afternoon. Quote Share this post Link to post Share on other sites
Deluk 0 Posted October 6, 2006 dont worry if it has full srevice i would get it after a good look :) Quote Share this post Link to post Share on other sites
vdubCorrado 0 Posted October 6, 2006 mass air flow sensors and coil packs is all that has ever seemed to go wrong on any i have ever owned or that my friends have owned... and 95% of the time you can just clean the mass air flow sensor with alcohol, let it dry, and put it back in... and coil packs usually noted to really crap out when they're chipped... Quote Share this post Link to post Share on other sites
peteTDI 0 Posted October 6, 2006 oil pumps pack up more so if on longlife servicing. make sure the cambelt and water pump been changed Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted October 6, 2006 Coil packs, MAFs, N75 valves & recirc valves are the things that tend to be a problem. Also dirty throttle bodies. By the way, whatever happened to that Corrado script badge? :? Quote Share this post Link to post Share on other sites
H8RRA 0 Posted October 6, 2006 Coil packs, MAFs, N75 valves & recirc valves are the things that tend to be a problem. Also dirty throttle bodies. By the way, whatever happened to that Corrado script badge? :? ...thanks for the info - the badge is still there i've just been horrendosly disorganised what with prepping the car for painting and now putting her back together. i'm in the garage this weekend and will try and find it..... Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted October 7, 2006 Cheers, dude :wink: Quote Share this post Link to post Share on other sites
owen01 0 Posted October 10, 2006 mass air flow sensors and coil packs is all that has ever seemed to go wrong on any i have ever owned or that my friends have owned... and 95% of the time you can just clean the mass air flow sensor with alcohol, let it dry, and put it back in... and coil packs usually noted to really crap out when they're chipped... were is the mass air flow sensor.mate Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 10, 2006 H8RRA, thats a lot of miles on an engine which suffers from quite alot of problems... tbh I'd try and find a lower mileage one unless it's really cheap! Quote Share this post Link to post Share on other sites
H8RRA 0 Posted October 11, 2006 £2000 is the price...... it drive really well but i don't know the 18t engine - Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted October 12, 2006 oil pumps pack up more so if on longlife servicing. make sure the cambelt and water pump been changed what he said. seen a few with 20 bent valves due to timing belts stripping after not being changed. also, seen crakced heads, from the water pump impeller deciding to detach itslef from the pump. Quote Share this post Link to post Share on other sites
