chuck 0 Posted October 24, 2006 Hello I have done a search on this and only found one, with no solution posted... Anyway, the indicators won't work, the warning lights do tho. When I move the stalk to indicate, the green light goes from faint to bright but solid and not flashing. The relay doesn't make a noise with indicators, but clicks and works fine with the warning lights. The fuse is OK too. Any ideas? I may change the relay, but I reckon its expensive... Cheers Paul Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 24, 2006 You checked all the fuses - ie it's a different fuse to the hazzards?? If not the above then maybe an earth problem - start changing bulbs Quote Share this post Link to post Share on other sites
