Bally
Front Wheel inserts
since having car resprayed I had the front arch lips removed & dont run inserts, seeing as the corrado is my daily driver the amount of dirt etc on the roads I need to maybe mod some inserts to try & keep the dirt from going right up in the arches..
also theres a small hole were the arch meets the the bodywork right at the top.. Ive noticed dirts coming up through the hole in the door channels which is annoying...
Ive painted & protected the arches but maybe need to wayoil the inside of the front wings & fill the top somehow???
any ideas peeps??
if you aint already make sure you waxoil the inner wings as you would be suprised to see how much crap can build up without the inner guards,.I ran my polo without these due to the lips being cut off the wings, just make sure you jet under the wings regulary
