fazgti 0 Posted October 29, 2006 Tried to look it up but just to make sure when i turn the key nothing hppens but all the elecs work fine so not battery, dont think its the starter either so it should be the switch, also i should be getting the 2l 16v switch even tho its running a 20vt, or is if different because of different ecu?.... Quote Share this post Link to post Share on other sites
mattkh 0 Posted October 30, 2006 Hi It could be many things. Can you put up a picture of the top of the starter. Make sure the picture shows the wires going up to it. Quote Share this post Link to post Share on other sites
fazgti 0 Posted October 30, 2006 Alright matt ill do it tommorow in the light! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 30, 2006 What is it actually doing - nothing at all?? Check battery voltage first then unplug red/black wire going to starter solenoid and check for 12V when key is turned... Ignition switch will be just a standard Corrado one (Polo 6N part) Have you got an alarm / imobiliser? Quote Share this post Link to post Share on other sites
fazgti 0 Posted October 31, 2006 Nothing at all, yea its got a concept 300but im sure its not that, it wont be the battery because you get a warning from your alarm when its nearly dead I just bought the standard switch and im fittng it tommorow ill keeep ya posted... Quote Share this post Link to post Share on other sites
fazgti 0 Posted November 1, 2006 Brilliant, fitted the new switch and its perfect Quote Share this post Link to post Share on other sites
slats 0 Posted November 2, 2006 getting a new switch tonight, how easy was it. instructions seem good but how was it for you? Quote Share this post Link to post Share on other sites
fazgti 0 Posted November 2, 2006 Well slats out it this way i havent got any dash anymore, na the difficult bit is just getting the screw out that holds the switch in, if you take off the top of the steering cover it makes just a tiny bit easier......but like every1 says persivere Quote Share this post Link to post Share on other sites
