leigha 0 Posted October 31, 2006 when i slide my heater control onto the screen setting, it slides back as if it's posessed! is this a common problem? here's hoping for an easy fix that doesn't mean taking the dash out! Quote Share this post Link to post Share on other sites
NickVR6 0 Posted October 31, 2006 sounds like a cable has come out of the clip that holds the sleeve in, so your moving the whole thing, not actually moving the wire inside the sleeve which needs to be captive. cant be sure though, as mines the later type, but sounds same symptoms i had Quote Share this post Link to post Share on other sites
leigha 0 Posted October 31, 2006 best pull it apart then... groan... ;) cheers! Quote Share this post Link to post Share on other sites
