godskitchen
Ash tray light.........
I want to use the power from the Ashtray light (light is facked) to power a USB powered MP3 player that runs on 5v, i have the Cig adaptor with 5v USB on the end, i was planing to just take it apart and hook up the Ashtray light cables to it.................... Is it that simple? I have had a search but nothing to answer this question........
Cheers!
this feed for the ashtray light will be 12v ,you need to reduce the voltage from 12 down too somewhere near 5volts a little over won't make any differance ,the cheapest way to do this is with a resistor from one of the big radio spares companies like "maplins or radio shack " don't wire 12v directly to your mp3 player it will just go bang
Rob
The cig adapter will be fine, just connect the feed from the cig light to the input in the adapter
