half-9 0 Posted November 16, 2006 OK - First apologies its an old topic. And I am really killing this one, sorry. I have searched on the forum, but can't find a solution... I have been calculating (on a spreadsheet) different wheel widths and the impact on the width of spacer needed to fit them (I intend to modify the arches). I started with what I think are the original fitments 6.5J x 15, et 33 I have assumed that 6.5j = 6.5 inches - Is this right?? Anyway - by my calculations 6.5J/inches converts to overall rim width of 165.1mm which when divided by 2 gives 82.55mm plus the offset +33 (mm?) equates to a rear rim width of 115.55mm. SO the distance from the wheel mounting face to the rear most edge of the original rim is 115.55mm. The logic I am applying here is that as long as I maintain approx the same distance between mounting face & rear rim edge, then I can get a alloy wheel as wide as I like but will then need serious arch mods to house it. (I hope your following me coz this is driving me nuts!) I then calculated for a variety of width & et combinations. E.g. I read Blue_Joe has 7.5j x 17 rims et 52 plus 25mm spacers SO 7.5J = 190.5mm, centreline is therefore 95.25mm plus wheel offset of +52 = 147.25mm as the distance from mounting face to rear rim edge. Hence he needed 25mm spacers which then reduced that distance to 122.25mm which is comparable to the original 115.55mm ( so clearance behind the alloy must have deteriorated by only 6.7mm) Great!! - but I think my theory is flawed as original 6.5J wheels were dressed in 195/50/15 tyres - which implies that the rim miust be at least 195mm wide not 165mm as per my theory above. I am confused by this. Can anyone shed anylight on this? Also how do I post my spreadsheet calcs on the forum so that someone can put me out of my misery. ANY help other than recommending a psychiatrist would be much appreciated. Cheers Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted November 17, 2006 lots of info here http://www.tirerack.com/tires/tiretech/tirespecskey.jsp Quote Share this post Link to post Share on other sites
